ih 3500a backhoe
I am in need of a hydraulic cooler that mounts in front of the radiator for a 3500a IH backhoe. If anyone can help me out please call 217 343 0413. I am also going to post a wanted ad, but I am in need of one pretty quick so I thought I would post here also. Thanks to all. Lee
If it is not a custom-fit part, I think you could use a finned air-to-oil cooler as found in cars & trucks & forklifts with the same functional effect.
Despite being a hydraulic system cooler, it is likely a very low pressure circuit or the cost of the cooler would be measured in cubic dollars.
Hi Lee, I believe the 3500A is based on agricultural model 674 tractor. I know 2500A is based on 574 tractor.
Hydraulic oil cooler for 674 is:
539560R1 COOLER, oil from caseih parrts.
If it is same setup as 674, as someone else said the hydraulic oil cooler is connect in the hydraulic return line that feeds the hydraulic brakes and the pressure is low.
Good luck
JimB
