I have an IH350U that was running but had low oil pressure. Pulled the crankshaft to have it ground due to front and rear main being out of spec.
Got crankshaft back and installed in engine and engine installed onto tractor
Per the manual the O mark on crankshaft gear should align with the O mark on the camshaft gear. The ll mark on the camshaft gear should align with the ll mark on the distributor gear. With both of these sets of marks aligned rotor in the distributor should align with #1 plug wire and the #1 cylinder should be at Top Dead Center and both valves should be closed on #1 cylinder.
So on my engine the rotor is aligned with #1 plug wire. Both valves are closed on #1 cylinder and #1 cylinder is NOT at TDC. It is at bottom of stroke. The keyway on the crankshaft determines where O mark on crankshaft gear is located relative to rest of crankshaft. It’s like mark on crankshaft gear is 180 degrees out.
I am confused.
Thoughts?
I am confused.
Thoughts?
