Replaced brakes on my gas IH 354: new disks, actuators, springs, balls. Left side seems to work fine.
When I put the case and assembly back on the right side, right wheel is bound solid before reconnecting
linkage.
If I back off the holding bolts so there is about a .015" gap between the case and the tractor it lets go and
turns smoothly. I have taken it off and redone it from scratch, same result. There is no gasket in the diagrams.
The only solution I can think of is to take it back off and grind one or more of the 4 surfaces.
Any Ideas?
Thank you
linkage.
Any Ideas?
Thank you
