Little Fred
Picked this tractor up from local dealer. Got it running nicely but no hydraulics-steering or 3pt.
We were able to bleed pump by cracking line but only for seconds.
Found out filter is missing some seals, the seal for the base and various seals inside the assembly as well as one spring. Would these missing seals and spring be enough to lose prime in pump? Never had to deal with a pump losing prime.
From reading posts here we were glad to find most of the filter assembly was present including the valve and screen. There was a fairly new element with clean oil so it appears someone worked on this not long ago.
