IH 434 gas throttle
toole
I'm trying to remove the cabinet below the throttle and steering wheel.I seemto be having problems figuring out how to remove the throttle handle and the steering wheel so I can replace the pin in the steering column tosteer the tractor.Thanks
Lever is probably just stuck, may need to heat and or devise a puller.
CNHI IH 434 parts diagram
That link will let you view all the parts diagrams for your tractor, that is probably obvious if you veiw it on a PC. On a phone selecting other Categories and diagrams takes you to other parts sections for the tractor.
