IH 444 Hydraulic Pump Identification
Bbrooks8159
I recently picked up a IH 444 gas w/ power steering. The tractor has the single hydraulic pump mounted on the right side of the engine. It does have dual
remotes. The tractor also has a 1501 loader on it. Through research i have noticed that there are several hydraulic pumps that it could take. 1 6 , 7, 9, 12
GPM pumps. Gas and diesel appear to be different pumps. I plan on using the loader on this unit as a second tractor to stack round bales in a lean2 where the
larger tractor cant maneuver.
What is my best option for a pump ?
Can i upgrade the the higher GPM pump and will it interchange ?
How do identify the pump that I currently have ?
Thanks to all that respond in advance !!
If your looking for faster loader operation in the hydraulic department you need to go to either the PTO driven pump on the back of the tractor with a through shaft for other PTO jobs. Or find an auxiliary mounted pump if they were available and I have to believe they were since they put backhoes on a bunch of those era tractors. It will probably be pricey since you will be looking for 2 things an industrial set up and a needle in a haystack numbering of them.
