IH 444 Loader Project (Hydraulic Filter Question)
RickMO
I am progressing on my project to add a loader to my IH444. I pulled out the suction filter to clean it and found the filter element loose and something inside it? (See Attached picture)
I purchased a replacement however the inlet pipe is quite a bit smaller.
Questions:
1. Should I just clean the old filter and use the old suction tube without the black thing from the center?
2. Should I use the replacement even though the pipe is smaller? (If yes I will need to rig some kind of coupling to the inlet pipe to the pump it is larger.
3. Should I cut the pipe from the old suction inlet assembly and braze it to the replacement filter body?
4. Is there anything special about the rubber hose that connects the suction lines? (I need to replace it)
thanks in advance Rick
Rick, welcome to YT! I can?t help you with your question because I?m not familiar with that model.
You may need to ask permission to post pictures as a new member. Go to the Site Comments
forum and post there with the topic ..Attn. Kim new member needs to post pictures. Also if you
took the photos with an iPhone or other newer phone chances are the pictures are to big in file
size and need resized. Best of luck!
