ih 444 rear end
i was wanting to know what rear end oil capacity is for a ih 444 rear end. Also how do you check it. If I remember right it is hy tran and you fill it 1" below the fill hole on the right side of the gear shifter.
With the high capacity hydraulic pump [ 15 gallon capacity ] full is 6 inches from top of threads on the fill bung just right of shift lever.
(quoted from post at 12:47:08 08/19/14) i was wanting to know what rear end oil capacity is for a ih 444 rear end. Also how do you check it. If I remember right it is hy tran and you fill it 1" below the fill hole on the right side of the gear shifter.
Standard oil capacity is 5 gallons. The plug to check the level is just under the step platform on the fight side, just ahead of the park brake lever. The front crankshaft mounted pump was an option for the 2444. If used the capacity was increased to 14 gallons and the level is checked by measuring down six inches from the fill plug.
As a 444 owner, Yup what Owen said!
Andrew
Standard oil capacity is 5 gallons. The plug to check the level is just under the step platform on the fight side, just ahead of the park brake lever. The front crankshaft mounted pump was an option for the 2444. If uses the capacity was increased to 14 gallons and the level is checked by measuring down six inches from the fill plug.
