Noel Putman
Hello all. I just bought an international 454 gas. I found that the rear screw in the distributor cap is stripped out. It would not start after pressure washing it and I found that the cap is not held on very securely.
This is a Delco 1112477 dist. Information I have found online suggests that this should have a Prestolite dist.
I am awaiting a set of manuals to arrive.
In any event, are there different distributors that can be used on this model? Could I helicoil this screw hole?
Is there a procedure for removing the distributor so I get the teeth matched correctly when I put this or another back in?
Thank you.
Thank you.
