IH 454 Lift Problem
Foxman
I was cutting with the bush hog and went to raise the lift. The lever only went up 3/4 of the travel length and stopped. The lift did not try to raise. Anyone have a idea? I looked in the manual and it suggested that I may have internal linkage problems. I am not familiar with the linkage or the lift and I do not know where to start. Any suggestions would be greatly appreciated.
Foxman, my I&T shop manual indicates problem could be:
a. Faulty main relief valve.
b. Faulty cushion relief valve.
c. Internal linkage disconnected.
If you 454 has aux hydraulic outlets, I would operate the lever for the aux outlets and see if the 3pt lifts. If the 3pt lifts the problem is probably dirt in one of the valves.
Good luck
JimB
