IH 460 Utility Hydraulic hose problem
Robert Neal
I have a 1958 IH 460 diesel utility tractor. The other day it developed a pinhole leak in the main hydraulic hose going from the pump to the distribution valves. I removed it and took it to a hydraulic hose repair shop. After going to the third shop, I found someone who said he could repair it. He put a new end on the top end and welded the bottom end piece onto a new end on the bottom. Using new hose of course. However, now
it does not fit because it seems to be about 3 inches to long and there is only a total of 4 inches of rubber hose now anyway. The real problem is what before was a simple right angle fitting, now is pipe with a 3 inch radius. That is how hydraulic hoses are made now, apparently.
Any suggestions as to what I can do now? I can't even start it because it would pump all of the oil out. Anyone know where I can get a replacement?
Any help would be greatly appreciated.
Whats the total length of the hose?? 1/2 diameter??? Get the length and diameter and then buy a pre-made one out of nnalert or Northern Tool. Thats what I've always done. There pretty cheap at nnalert tractor parts. Can look them up on the internet, nnalert.com
Ryan
