IH 464 hydraulics not working
Robbie Gooch
I have a IH 464 that I changed the hydraulic filter on and now the hydraulics are not working at all. It all worked as it should before the filter change. The tractor did sit for a couple days with the filter off. Any suggestions?
Make sure there is plenty of hydraulic oil in the trans/diff and also that the hydraulic filter canister was installed correctly with no air leaks.
If still no prime to the hydraulic pump then with a clean bucket under the MCV hydraulic filter area loosen the connection for the high pressure line to the power steering, start tractor and shut off when hydraulic pump primes.
See attached photo of MCV and connection to PS circled in red.
