IH 464 rear weights
Anonymous-0
Purchased a 464 utility recently. I have fluid in the rear tires but it seems to need some wheel weights. What fits it? I tried to match up the cast half weights off of my 560 but dish in the pressed wheels along with the bolt holes don't match up. Weight holes are 11 inches.
Weight bolts off the 826 are wider still.
Unlike hayray, I had a 464 some years back, and it was a good tractor. The weights you need are for utility tractors. Any from a 74 or 84 series will fit it. They are smaller than the old red ones. Try letting your tire pressure down to about 8-10 pounds in each tire. That should help.
