I was working the tractor yesterday and when I went to idle down it was stuck at the same idle speed. I figured it was the adjustments. By hand I could turn it up and down by the lever on pump and it had No affect on the idle speed. It is currently stuck about half idle. (That is good, I can still work). I took the arm of the injection pump and turned the idle speed shaft and it will turn in circles and has no affect. It appears the shaft that the arm mounts to is either broke or not connected inside. I'm wondering if I can pull the shaft to see if it is broke or damaged before sending it off for repair. Highlighted in the photo. What is your advice please.
