IH 484 wheel weights
soupkid
Im looking for a set of wheel weights for the back tires of my IH 484.
I see lots of wheel weights for sale across multiple forums but I have no idea what I need.
The tractor has the OEM right size tires but no idea about the rims.
Can anyone help ??
Is it the utility model without the bar axles?
My brother has a 454, one generation older than 484 without bar axles and he has rear wheel weights from a IH 300U or 350U on it.
See this link: https://forums.yesterdaystractors.com/threads/wheel-weights-365321r2-370685r1.979117/
From Caseih.com parts:
Single Piece Weights:
First weight: p/n 3123758R3, WEIGHT; 120 lbs, used w/28 or 30 in. attached clamp wheels w/8 rim clamps, first set
Substitutions: p/n 3123758R2, 3123758R1
Second weight: p/n 406857R5 WEIGHT; 120 lbs, used w/28 or 30 in. wheels, second set
Substitutions: p/n none
Two Piece Split Weights:
First weight: p/n 365321R2 WEIGHT; rear wheel, 75 lbs, used w/28 or 30 in. wheel, first position
Substitutions: p/n 365321R1, 365320R91
Second Weight: p/n 365321R2 WEIGHT; rear wheel, 75 lbs, used w/28 or 30 in. wheel, second position
I don't know about the numbers part on this but with our 574 with the disk center and loop rims you can bolt any of the cast weights with the rectangular hole in the center like seen on most of the H,M and on up models with no problem as long as you don't try to put the weights on for the Cub,A,B,C series tractors. Those usually will be the smaller diameter cone shaped ones that have a thick side to them about 4-6 inches.
