IH 574/674 Gas
jmill00
I think the engine is a model 200. Not sure though. what I'm curious about is how to determine which distributor I have so I can order a solid state ignition upgrade. Also, does anyone have any suggestions on suppliers for these kits?
Hi, according to caseih.com parts:
574/674 Gas is C-200, serial number on right
side above oil filter.
See 574:
http://partstore.caseih.com/us/parts-
search.html#epc::mr50613ar42757
See 674:
search.html#epc::mr62746ar145499
Hope this helps
JimB
On the IH 200 motor the IH distributor cap is held on by clips, the Delco Remy distributor cap is held on by screws. Otherwise to be sure you may have to pull the distributor in order to see part numbers.
(quoted from post at 14:21:44 02/28/15) On the IH 200 motor the IH distributor cap is held on by clips, the Delco Remy distributor cap is held on by screws. Otherwise to be sure you may have to pull the distributor in order to see part numbers.
Excellent, that's exactly what I needed. Thanks much.
