I have an IH 574 gas tractor that runs well but overheats when working in air temperatures over 70 deg. I've recently replaced points & rotor, set the timing to 20 deg and blown the exterior crud out of the radiator fins and engine air filter. Coolant is 50/50 mix Prestone & water. Also, have recently acquired a new Tebben 60" rotary mower to replace an ancient JD mower of the same size. At full throttle, tractor runs at about 2100 rpm when driving the mower (but not cutting), and 2300 rpm when not loaded. Any suggestions on how I might get this old girl to get a little less hot under the hood?
