I was doing some mowing with my IH 684 tractor, and about 30 minutes in, I noticed my engine sounded as if it was it was slowing slightly, and then it dropped off noticeably, and started to "surge" then back off, then rev, then back off, etc. I stopped, stopped the cutter, and it evened out. I continued on, made another round, and it was fine for a bit, and then it returned, and got increasingly worse. I drove it back to house and turned it off.
On the face of it, it sounds like a fuel problem. I've got half a tank of fuel, fuel filters have been replaced quite recently, and I mowed for several hours on the same tank of fuel just this past weekend - no problems whatsoever.
Also recently, I drained and replaced the coolant in this tractor. This was prior to its use this past weekend. I mention this because it was a recent change. My thermostat didn't show any high temp (I assume it works). Is this behavior that could be explained by overheating? That seems unlikely to me to be related...but what do I know?
Anyway, any trouble shooting advice?
Assuming fuel:
* The fuel itself (contamination?)
* Tubing (flow)
* Filters
* Injector pump
* Injectors
Any other possible culprits?
Assuming fuel:
* Tubing (flow)
* Filters
* Injector pump
* Injectors
