IH 684 Valve adjustment
Riversea
Hi Everyone. Just finished rolling the tractor together after replacing the rear seal, clutch, flywheel resurface, etc. Before I install the engine shroud, I thought it would be prudent to check / adjust the valve clearances. The factory spec is .012 for intake and exhaust respectively, with engine hot. Seems like a step (warming up and polluting the shop air) could be saved if the factory published a cold setting. Has anyone bothered to measure the difference(s) between a hot (.012) and a cold measurement on a 684? If so, what was the cold measurement? Thank you for your reply(s).
Just open the door or run it out the door for a bit till it warms up then check it inside. Could also put a pipe or hose to it to exit the building during running.
With I H and many others what they say is HOT is room temp of 70 Plus degrees and to get to Operating HOT this takes a good deal of Working time to get everything up to working temp and on a diesel ya got to work them to get there just setting running they COOL DOWN .
