IH 686 3 point control question
ctb1980
I have a 686 that I use mainly for mowing with a Bush hog rotary mower. Here lately when I start up the tractor and want to lift the mower, I have to hold the 3 point control lever back until the mower raises or the lever wants to go back forward. Once the more is up it will stay but if you are driving down the road or through the field, it will bounce down. Can someone tell me if there is an adjustment for this? It seems like I had to do something with this some time in the past but I can't remember what exactly. Any help would be greatly appreciated.
Sounds like the friction disc needs tighten.should be at the bottom of the lever where it connects to the rod. Can't remember which your tractor would have for friction. It will either be a nut on the end of the shaft or a clamp style that goes around the shaft.
I believe you have to take a socket and extension and tighten clamp around lever shaft. It think it 1/2 size socket if I can recall. You get at it from back of tractor.
