ih 784 Bosch fuel pump
Anybody know where I might find a gasket/seal kit for my ih 784. She has a Bosch fuel pump and the gaskets are leaking. pump works fine, just leaks
the gasket on the rear of the body, just in front of the section where the fuel lines come out going to the injectors.
VA late CR models use Bosch DGK 124 kit, pump injection line outlets are straight out. Early VA AR and BR models use DGK 125, these pumps have angled line outlets.
Forgot to mention, your leak is at the head O ring, no gasket there. Be very careful with throttle and spill plungers as parts for this pump are very hard to find anymore. Just had a 574 CR come in, owner has broken the spill plunger tab, have not found another head yet as parts are mated assembly.
(quoted from post at 22:08:28 05/07/13) The overhaul of the pump is covered in the fuel pump service manual.
i sell copies in PDF format drop me a line to <[email protected]> if interested !!!
I might be interested in the manual, I'm having the same kind of iddues with a VA 4
(quoted from post at 11:08:00 05/24/13) Drop mean e mail with your e mail address and which manual
you require??
How do I drop you an email without posting it on an open forum
