IH #8 Plow frogs
Grizzybear
I am looking to upgrade a #8 plow from the cast shares to the newer throw away type I think they are for a 3-bolt share + called a super chief type. I went to the local
Case IH dealer + they just laughed at me
. Looking for a source for the materials to make this happen. Even if the frogs + moldboards are good used ones.
Thanks
Grizzybear
Yeah, new frogs are $500 each, if you can even get them. Used ones are $125 each at a scrapyard. $100 for the moldboard, $15 each for the landside, point/share, and shin, plus bolts, plus braces.... You'd spend a fortune.
Your best bet will be to find a newer 3pt hitch type IH plow for sale locally, cannibalize the bottoms off it, and sell the rest for scrap.
The frogs all have the same bolt pattern. I've read several accounts of people converting old #8 plows to super chief by simply bolting on the frogs.
Plow frogs are what you bolt the shin to. This actually bolts to the plow beam with 2 or 3 bolts
Shins are a wear piece that "Cuts " the ground at the inside of the furrow. Below the shin is the landslide. Other than the share + the moldboard that is all there is to a plow bottom
I have a brand new set of moldboards and points , I know there IH but they dont match my plows But I do have 3 or 4 sets of IH plows here, In Central NY.
MagMan
(quoted from post at 12:10:47 06/04/08) I have a brand new set of moldboards and points , I know there IH but they dont match my plows But I do have 3 or 4 sets of IH plows here, In Central NY.
MagMan
Hey Magman, you don't have any spare coulters around do you? Need 1-2 for my #60 plow so I can turn up some sod. Figure at least one for the rear bottom so it leaves a nice furrow for the next pass... Pullin three 14's with a 5220 Maxxum so power and traction aren't an issue.
Tom, here's a quick primer on plow parts, assuming a conventional plow. All directions are looking at the plow from behind:
1. Beam - The heavy cast piece that connects the bottom to the frame.
2. Bottom - The sum of the beam, frog, landside, moldboard, shin, share, and point.
3. Frog - The underlying frame for the plow bottom. All other parts bolt to it.
4. Landside - A wear plate that rubs against the side of the newly-dug furrow to keep the plow moving straight.
5. Moldboard - The large piece that turns the soil over and drops it in the open furrow to the right.
6. Shin - The leftmost piece of the moldboard. Early plows had a one-piece moldboard, but the Plow Chief and later Super Chief designs broke it down into a moldboard and a shin because the shin wears out at about the same time as the point/share, but the rest of the moldboard wears much more slowly. You can go through several shins before wearing out a moldboard.
7. Share - The lowest part of the plow bottom that digs the soil free across the width of the furrow.
8. Point - The very leftmost tip of the share. The point pulls the plow bottom into the ground. On the Plow Chief design, the point is a separate piece. Most bottoms have a one-piece point and share design because both wear out at roughly the same time anyway.
Please make corrections as necessary, anyone.
