IH 884 starter
cool hand
Location
SE IN
Went to start my IH 884 and the starter jammed in engaged mode. It has a loader on it which prevents easy access to the starter, so it continued to run until I could disconnect the battery. I'm sure it ruined the solenoid as it was smoking greatly. Question is: Is it likely to simply require replacement of the solenoid, or will the starter itself require service or replacement? TIA for help!
Looks like three different starters were used, Lucas, Delco, and Bosch. I'm NOT sure if they all fit, or if anything else changed along with the make of atarter.
How it's repaired or replaced will depend upon the cost of the needed parts and the brand name you have.
The solenoid could have simply stuck/contacts welded, or the drive or linkage to it could be worn, loose, or coming apart.
For some starters, the way parts prices are, by the time you buy a solenoid or a drive and figure in some labor you might as well have bought a new or re-man starter.
There's some good aftermarket ones out there with a price that beats messing around repairing your old one.
<img src = "https://i.imgur.com/BVBwOt8.jpg">
New aftermarket starter.
THIS very site, yt, has a couple of choices of re-mans available, as well.
As usual, I can't add any information to Bobs response. I can only offer an opinion. If the starter is a Lucas I would take it off and throw it away. My luck with them has been 100% bad.
If this were my machine, I would remove and disassemble the starter just to look over the insides.
