IH 966 rear remotes
jp1977
looking at IH 966 it has a loader using both sets of rear remotes can you buy a kit to add a 3rd set could you tie into the hydro line and not use the rear remotes for the loader ?
What you need is a 'power beyond' block.It bolts to the 'backside' of the valve stack,giveing constant flow.
The power beyond block will go in. Will have to cut a hole in the LH seat support for the hose ports to go out. Used to send a template with the factory kit. You will be able to see what needs cut out.
thanks for the info about the power beyond kit I have put one on a jd didn't know they called it the same for international. Does the 966 have any common failures to look for
We put a beyond block on our 966 and used it as our loader tractor. It NEVER needed anything but fuel. It is one of my favorite tractors. I sure wish it would have had a/c, but back then we didn't know any different.
