bubschevy
Hi, this is my first time here so I hope the question I have is allowed. I am restoring a IH Cub 149. I started my taking the rear fenders off so I can address a hydraulic leak. After I clean 40 years of oil from the pump and rear end, I noticed some burned wires. someone has bypassed the neutral safety switch. I stripped the harness and replaced the bad wires. my question is according to the wire harness for this tractor it is supposed to have voltage regulator number IH 545130-R93 which has B, G, F and ground. the voltage regulator that someone replaced has L, B, F and ground. They had the F wire going to the A post on the generator. I know L is load, B is battery F is field and of course ground. my question is will the V/R that has L, B & F work? if so, how to wire it. I hope this makes sense. Thanks for your help.
