Ih d282 fuel pump
Gleanerk2
Working on this 656 got her warmed up in the shop I have no fuel coming out of the return just a few bubbles out of the return line elbow at the pump! I had alittle bit of fuel at three injectors the other day but I was outside in the cold now I have ni fuel at the injectors took return off and left it off to see if that helped incase return was plugged but all I get is a couple bubbles at the return elbo good flow goin into the pump! Any ideas
Can you give it a bit of air pressure in the tank while cranking? Just a little, don't get excessive, you don't want to rupture your tank. You probably have a stuck/sticky plunger, putting air to the tank while cranking may help get things moving. I know it's not the "right" way to do it, but hey, if you are thinking that the engine needs to maybe be replaced anyway, you won't hurt anything.
Ross
If it has set awhile since running injection pump may have several critical parts stuck inside. Just repaired a Continental GD 193 pump from an IH 350 utility. Metering valve, delivery valve and plungers were all stuck TIGHT from old stale/rusty fuel.
