IH Disc,friction
Hello everyone!
Im looking for part #1212818C1
Its a friction disc in a 4500b iH forklift
Transmission!
Need qty 12
Any ideas?
Thanks for any help!
Part numbers are great and pictures with dimensions even better. If small enough you might be able to use old cutoff wheels for the friction disc or new ones if needed bigger or old friction linings from something else.
You might try this company in Idaho, see link clutch plates are one of their specialties. Your part number doesnt come up in a search on their site. Phone call for a long shot. You have an orphan machine, which I suppose you know.
CG ..old cut off wheels.. in a transmission? I guess desperate times.. desperate measures.. ; > )
(quoted from post at 15:49:42 01/23/23) Thank you for your suggestion!
I might have to try anything soon!
You're dealing with an orphaned machine with absolutely ZERO parts support or availability, pretty much since IH sold the construction division to Dresser in 1983-ish. Dresser only wanted the dozers, and dropped everything else pretty much on day one. Once the parts ran out for everything else that was the end.
You might be able to get the discs you have currently, relined unless they are warped or something...
A little more info might help. Like are you talking about a clutch disk similar to a automobile with standard transmission, one that has a splined hole in the center?
A picture maybe with a ruler laid next to or on top of it might help.
If it is in fact similar to an automotive clutch might pay to contact some outfits that deal in antique car parts I would bet that there are places that can rebuild yours or maybe even match up with something on the shelf!
One more suggestion if you can also provide a model number and serial number of this machine I could ask over on a heavy equipment form if any one there would have some ideas. There are many people who have been around equipment for decades if the parts are out there they might know where to find them.
This post was edited by kshansen on 01/24/2023 at 09:47 am.
Thank you for you suggestions!
I wont be able to get pictures until this weekend!!
The model is 4500B
Pretty sure its a 1982 model
Serial # 0440078B200798-x-
#13 in the image
Joesph Industies carries a lot of friction parts. They have a website. You could give them some pictures and good measurements. So are these for the shuttle and are they the ones with the bronze type faces?
