I have just purchased a new to me disc that I believe is a model 370. I have a model 37 with nine blades per side in front. This disc has ten.
What size are these two discs?
Need more information. They were made with a 7" or 9" blade spacing and could also be gotten with one spacing on front section and the other on the rear section so need to know blade spacing. Once I know that I can look up the width of cut in my No. 37 book. The 9 blade would be 2 1/2' wider with the 9" spacing over the 7" spacing.
I have an IH 370 disk which measures 14 feet across the rear. It has 12 blades per side at 7" spacing. So I would say if you 10 blades per side at 7" spacing, it might be a 12 ft. So just measure your disk across the back and then you will know. An IH dealer once told me that's how you measure the IH disks. Al
That is how it is listed in the owners manual, back gang set in full cut and at the end of axle. 7 blade 7" is 8'8", 8 blade is 9'10", 9 blade is 11'0", 10 blade is 12'2". Now if it is a 9" blade spacing on a 10 blade model you have 9 spacings that are 2" wider or 18" on each gang or a total of 36" more on width so a 10 blade 9" spacing would be 15'2". So blade spacing does make a big difference. At a 7" spacing a 17" wore down 18" blade will do good but on a 9" spacing you need what was the optional 20" blades to break up the dirt space between the blades.
