IH hydraulic cylinder value
Al L. in Wisc.
Part # 360 998 R1 is an IH hydraulic cylinder. If I am measuring this correctly, the cylinder itself appears to measure 12" by 3". It has a little curved 'stop tab' on the end where the part number is stamped. I would appreciate someone providing me a value. Thanks in advance for your help.
Al, Part no. 360998R1 appears to be a component of hydraulic cylinder p/n 360994R91 as 360998R11 consists of several parts which make up the front head of the remote control cylinder which is used on the Super
C, 200 and 230 Farmall hydraulic system. The part no 360998R1 you note is probably just the casting of the R11 assembly which is shown in my part catalogs for the noted Farmall tractors. The parts catalog
notes it as a Remote Control Cylinder (2 1/2" X 8" with 3/16" dia. limit stop valve). Also, noted are (2) 1/4" I.D. X 100" hydraulic hoses which terminate with a 353216R91 break-away rear section coupling
assembly which must attach to the cylinder. Hope this is of some value to you in determination of it's value, Hal.
