Jim Ullrich
All,
I keep an old IH TD 15C at my sister's farm. A month ago I shut it down and the starter was still spinning.
Tried to kill it with the ground switch but that didn't work, so, disconnected the batteries.
Got the starter rebuilt, and bought a new ground switch.
I took a picture of the wiring before I took out the starter, but could use a sketch or picture to make sure I got it right.
Tried to start it; the starter spins but doesn't engage.
Guessing it's the magnetic switch.
Any help is greatly appreciated; I am a soil scientist, not a mechanic.
Thanks,
Jim
All,
Thanks,
Jim
Hello Jim, welcome to YT! If your starter has a solenoid attached most often what you have happening should be a problem internal to the starter. I assume by you description it only spins and does not grind when you try it? Here is a link to a tractor parts place in Idaho, the main thing the sell is replacement clutch plates for crawlers. It also happens that they have manuals stored there to access, they are at the bottom of the linked page. Crawler clutches and manualsThe top link in the second section is the “TD15B 175B Crawler Service Manual” go to PDF page 37, that will be the Powershift model wiring, the one following that they call “Custom Application” which appears to not have the safety start switch. Take a look at this and let us know further questions. A photo of the starter may be helpful, but IH use mostly Delco components so the basic layout is the same.
