IH444 Charging system question
old
Ok so got a call this morning from a guy who has a IH 444. He says the charge light is flashing on and off as it is running. Any ideas as to what I will find when I go check it out a bit later today?? Also is this a generator system or an alternator??
Thanks
Likely has a Delco 10DN alternator and parts catalog calls for a "flasher bulb" for the oil and charging lights, so that explains the flashing.
Well the guy say when it was working before I did some work to it the light would come one when the key was turned on then go out when running. Found that the battery reads 14 plus a little volts when not running and around 18 volts when running which seems a bit high to me
If the idiot light is flashing slowly (like once a second or two), problem could be as simple as a slipping alternator drive belt. So check the belt tension before proceeding!
ALSO.....it sounds like your voltmeter calibration is way off:
A fully charged battery at rest (no charge or load current) will show 12.6 volts MAXIMUM. Your reading of 14+ volts is way out of whack.
Similarly a reading of 18 volts while charging is too high - 14.5 to 15.0 is the maximum you should see.
The belt is the first thing I checked and then tighten up.
As for the meter I have used it in the past to test charging systems and this is the first time I have had readings like these so I think it is this tractor not the meter. As in the charging system is in fact charging at to high a voltage.
The other day I had to do some wiring on it because the ignition system was not working so rewired the ignition system with a ballast resister and since the fuel pump worked when the key was turned on just tapped into that to make the ignition work
This is how it is wired:
The junction block is actually the starter solenoid.
Old, I also have never found a battery reading that High, Test the meter on a new alkaline flash light battery they read 1.6 volts. Test it on another good car battery. My regular pretty good meter started to gain volts a year ago and just became unusable. Jim
Just tested a brand new AA diehard battery and it read at 1.58 volts so my meter is reading as it should go goes back to that tractors charging system is over charging
You might check your meter on your car with it at rest and with it running.
A reading 14 volts from a standard automotive battery at rest is simply not possible - fundamental lead/acid electrochemistry precludes it.
However a voltage reading of 18 volts while charging IS possible. I ran into it once on a CIH 9280 with a bad (shorted) voltage regulator. It seriously overloaded the alternator which overheated and quit working after about 30 minutes. It also raised h*ll with the battery - it boiled acid out until the alternator quit.
Guess I should also fill in a blank. I checked that tractor battery less then a minute after shutting it off so the battery could well have read 14 volts due to the fact it was having 18 volts pumped into it less then a minute before I checked it
Just checked the car battery in the car I drove today. Battery in it reads 12.84 volts which is about normal so the battery in this IH444 is getting over charged and that is why I get the 14 volts on it. But as I said I took the reading not 5 minutes after it had been running so yep battery may go back down after a while but not right away
