IH444 gas ignition switch
buffbenj
1967 IH 444 gas. Engine runs perfectly with temporary switch "on", then jumping at the solenoid. Got this new switch & need help running wires to it, with inline fuse(s). Terminals read B, ACC, S, P, & G. Won't need ACC, since lites are not wired. G can just come from frame, right? What is P? Thanks in advance.
(quoted from post at 08:40:39 11/13/20) 1967 IH 444 gas. Engine runs perfectly with temporary switch "on", then jumping at the solenoid. Got this new switch & need help running wires to it, with inline fuse(s). Terminals read B, ACC, S, P, & G. Won't need ACC, since lites are not wired. G can just come from frame, right? What is P? Thanks in advance.
Where did you get the new switch, from CIH, or is it aftermarket?
My best GUESS as to the markings:
B = Battery
ACC = ACCESSORY
S = "Start" (to solenoid)
P = Terminal that gets powered when switch is "ON"
G = Ground (Used to test warning lights, if so used, and tractor is wired for this function.)
Good luck, use info at your own risk!
Do you have an ohm meter?
It's a pretty sure bet the B terminal will be power from the battery.
Put one lead of your meter on the B terminal, start turning the switch and see what terminals connect in each position.
I would not ground the G terminal! No reason to ground any terminal of an ignition switch. Good chance the G terminal is for glow plugs if it were used on a diesel. If so, and you ground it, it will short the battery terminal when the switch is in the G position.
If you are going to use a fuse, only need to fuse the feed to the B terminal. If you use an inline fuse holder, choose a heavy duty one, or go with a spade type fuse holder with a cover. The spring type inline holders tend to be loose and don't like the vibration and rough service of a tractor.
