I am cutting hay with a borrowed IH 674 diesel tractor pulling a New Holland 489 haybine which uses a single hose for raising and lowering. I was having increasing trouble getting it to come down, although it would raise up easily, and at the very end started getting hydraulic fluid spraying from under my left foot around the hydraulic dipstick. This was following by a partial loss of power steering, but I made it back to the barn with the haybine raised and fluid all over the left side. Now the haybine won't come down, even with the tractor parked and shut down, and the dipstick shows no fluid, but there is a lot on the ground.
There are no flexible hoses under the footpad in that area, and all the fittings seem tight. Would this unit start throwing fluid if it got real low? Any ideas as to what the problem is?
