Good day all, having some issues with my 806 International.
To start I purchased tractor several years ago for the soul purpose to sit in one spot and run my processor. Tractor has shifter issues but that didn't matter as I was only using tractor as a power source,
so to speak. Well after sitting several years, and as with many of us we have to many projects to work on, I decided to get it running again but found it would not start or smoke at all.
After draining fuel and putting new fuel in I still couldn't get fuel past the pump either at the pump or up top at the cracked injector lines.
So I came to the conclusion that the old fuel had plugged up or seized parts inside the pump due to old fuel. Fast forward to getting pump rebuilt and reinstalling only to find still no fuel coming past the
pump with throttle in any position (same as prior to pump rebuilding).
Someone mentioned to me that maybe the return lines are plugged, so took off lines and blew them out as well as loosening return lines on top of the injectors.
So basically pump (rebiult) is on engine with all lines loose except fuel feed line which has lots of fuel coming out when loosened as well, and no fuel comes out of pump or up to injectors.
This is the Roosa master system as well, not the old RDW system.
Also should mention that injection shop did say they couldn't find anything that would have caused a no fuel issue, as they did with my MF 1135 that also had same issue, but a rebuilt pump, filters and new
fuel and that one is running nicely.
So I'm leaning towards that there's something else causing this that I'm just missing, as it's the same issue before and after rebuilt pump??????
Any have any ideas as to what might be the issue?
Doug
Doug
