onion farmer
Can anyone tell me what planter plate do I use to plant sunflowers with my IHC 295 planter .. Thank You for any help with this issue.
Looks like 3143A plate & needs a 1902A filler ring.Can anyone tell me what planter plate do I use to plant sunflowers with my IHC 295 planter .. Thank You for any help with this issue.
Thank You Mike for the info that helps a lot. Would you know of anyone that would have a set, as I only have a single row planter.Looks like 3143A plate & needs a 1902A filler ring.
Mike
So far, I haven't found that plate outside of going through CaseIH & they want $94.50 for it!!! One other option is to contact these guys:Thank You Mike for the info that helps a lot. Would you know of anyone that would have a set, as I only have a single row planter.
Do you have any plates at all? I've been known to dremel out the seed cells in a plate to get what I needed.Thank You Mike for the info that helps a lot. Would you know of anyone that would have a set, as I only have a single row planter.
Hi, Yes I did try Ebay but did not find what I needed, Thanks .... Dave.You might check out eBay too, that's where I found the sunflower plates (and lots of others) for my 186 planter. The prices were less than half of Lincoln Ag too.
Mac
Hi, Yes I do have some plates , I guess I never gave it a thought but I could try and see what happens with one, What I don't understand is why do I need a filler ring as well, what is the purpose.Do you have any plates at all? I've been known to dremel out the seed cells in a plate to get what I needed.
Here's what you need, both the plate and the ring: https://www.ebay.com/itm/403596690685Hi, Yes I did try Ebay but did not find what I needed, Thanks .... Dave.
Have you checked Lincoln Ag Products yet? They have pages of sunflower plates for all brands of planters. So they're not even special order. $65 seems to be the going price, and they say you need a filler plate which is another $65.Hi, Yes I do have some plates , I guess I never gave it a thought but I could try and see what happens with one, What I don't understand is why do I need a filler ring as well, what is the purpose.
Well I went out to the barn and found a stash of planter plates but not the number plates that I need , But I did find a filler ring that I have no idea where or when I got it, it was from Lincoln AG Products, it is .155 Thick, with the only number on it is CFR-3, any idea what this would go to..The filler ring goes between the plate and the hopper bottom. That's because the sunflower plates are flat drop, and as such, the plate has to be thin. The ring makes the plate stay tight to the seed hopper bottom so it can be driven and not skip.
The plates that I listed are $25 each; the ones from Lincoln Ag are $65. I am not affiliated with the seller of the ones I listed in any way; however I'm not for spending twice the money on the same product.
Mac
I just tried to buy the plates an was told there is no such site.Well I went out to the barn and found a stash of planter plates but not the number plates that I need , But I did find a filler ring that I have no idea where or when I got it, it was from Lincoln AG Products, it is .155 Thick, with the only number on it is CFR-3, any idea what this would go to..
That is the exact ring you need for the sunflower plate, if my memory serves. Here's a link to Lincoln Ag: https://lincolnagproducts.com/CFR-3, any idea what this would go to..
I will do that Mac ,Thank You for your help I will let you know how I make out..... Dave.That is the exact ring you need for the sunflower plate, if my memory serves. Here's a link to Lincoln Ag: https://lincolnagproducts.com/
Before you order them, look around the barn again; odds are if the filler ring is there then plates are too.
Mac
You're most welcome. Do also check that ebay link in my other post. Might be what you're looking for at half the cost of new.I will do that Mac ,Thank You for your help I will let you know how I make out..... Dave.
Can't help ya there. Might get a better response down on the Ford board.Has anyone installed a power stearing unit on a Ford 650, it also has a three point hydraulic leak as well.
Hi ,Mac I did find the correct plate on Ebay and got it installed so all i have to do is waite for spring to get here, Thank you and every one else for the help on this issue I could not have done it without you all. ....... Dave.You're most welcome. Do also check that ebay link in my other post. Might be what you're looking for at half the cost of new.
Mac
