Improved starting
8deers
Bobcat Diesel started this morning at -28 F without being plugged in. Needed to pull a car out of ditch. Snow sure is sqeeky.
(quoted from post at 10:39:55 02/13/20) Bobcat Diesel started this morning at -28 F without being plugged in. Needed to pull a car out of ditch. Snow sure is sqeeky.
Glad it started for you, any time I have had to start something not plugged in when it is really cold out, all I can think is;
How many years did I just take off the life of the poor thing by doing that.
I used to plug the feeding tractor in every other day as we feed every second day, now when it is cold I keep at least one plugged in 24/7.
You never know when something is going to come up and leave you scrambling; a power failure, snow storm or as you had a vehicle to pull out.
A buck a day for power seems real cheap when things start breaking.
My gosh that's impressive. Reminds me of when I had JD 4230. It could be 80 degrees out but if weather man forecast cooler weather, it would not start.
Some of you saying about cold starts. A friend of my dad ,he snapped the bendix right off. Just a little too cold.
That is impressive.
Dad would use the Farmall H when it was well below zero back in the day, it had a magneto and would start whenever. The magneto went bad and he stuck a points distributor in instead of rebuilding, it didn?t start the same in winter after that. Gas engine of course.
My New Holland 1720 will start at 5 below F I?m impressed enough with that. Might need a charger on the battery to get it warmed and topped off a bit if it hadn?t been running the day before. I?ve coaxed it to start at 10 or 11 below, used a little bit of magnetic heater when I can it doesn?t add much but makes the oil a little thinner at those temps.
Paul
My 4020 will start at 25 below without ether or being plugged in usually have to put the battery charger on overnight though
(quoted from post at 08:39:55 02/13/20) Bobcat Diesel started this morning at -28 F without being plugged in. Needed to pull a car out of ditch. Snow sure is sqeeky.
35 years ago I lived in Bemidji Mn, for 13 months. The temp one morning was -38, and my pickup was an old red chevy with 3 on the tree and a 6 banger. Engine block heater was plugged in, and she fired right up.
When I went to shift from reverse to 1st, the lever was so stiff I could hardly move it, and then the linkage under the hood broke before I got into first gear.
Man, that place was cold!
