(quoted from post at 16:49:42 09/27/21) ISO a J.D. mounting plate for a 350 sickle bar mower P,N, E62199 it go on the draw bar.
(quoted from post at 13:49:42 09/27/21) ISO a J.D. mounting plate for a 350 sickle bar mower P,N, E62199 it go on the draw bar.
thank you(quoted from post at 15:20:08 09/28/21)
I don't think it needs to be exact, as I expect they didn't design it with a Massey in mind. The two holes need to match your drawbar holes and be set in an inch or a bit better from each edge. The hole diameter for the offset needs to match the eyebolt. I would say it would be offset 6 to 8 inches from the drawbar holes. You should be able to see how much offset it needs to be, to be under the lift arm when the mower is hooked on. For thickness I would go 3/4" to 1". Just my thoughts.
(quoted from post at 09:00:33 09/29/21)thank you(quoted from post at 15:20:08 09/28/21)
