Ind PTO clutch
Bill C
Where is there a write up on how to install the pins and springs that you get when you buy the new parts from Massey that do not use the wave springs. bill
The pins and springs always set on the tabs of the first steel plate against the clutch piston. Also place the plate so the pins/springs are not inline with the drum bleed holes on the side as much as possible.
