Initial Tire Pressure Setting
REDEYE
Moving up to a 4010 after pulling smaller stuff for years. Also moving up to 18.4-38 BFGs from 15.5-38 FS-151s. Given all the changes I am going back and forth over what tire pressure I should run the first time down the track. Will be pulling 3.5 mph 7500# with 2300 on the front axle and 5200 on the rear. If it rains tonight track will be hard, packed and hook hard, if no will be dry and a medium packed. What tire pressure would you run?
At 7000 with 560 Farmall and BFG powersaver radials 8psi works good. But on a really hard track the firestone 23 degree radials will work better.
