Injection Pump Question
super99
I've wondered about this for a while. I'm not a machinist but have worked in a machine shop. The pumps on old Olivers and others used a pump that had tendencies to stick when they sat too long and then break shafts and heads and parts are nla or very hard to find. Why couldn't someone in a machine shop make new replacement parts to keep these pumps running? We had some machines that were 30 years old that used a computer program to run the parts, couldn't someone write a program to make replacement parts? I'm sure it would be expensive, but the more parts you make they should get cheaper to make each piece? OK, flame away!! Chris
I have wondered the same thing. Like J said each one would have to be individually fitted. The plunger is smaller in diameter than a pencil. I have heard rumors that someone does it but nothing for certain. I have also heard that they send them to another country to be rebuilt.
I have one tore down somewhere. I will try to post a pic.
The four and six cylinder heads were built with 7.0 to 10.0 MM plunger sizes in .5 MM increments. The head, plunger, and metering sleeve are finely lapped-mated parts, too loose and fuel will get past the lower area and into the crankcase, too tight and parts will seize. PSB heads that have letters AR were factory rebuilt. Most Olivers used head HD 3690AR, but there were early square heads too. Bottom line is, easier said than done. Unless heads can be made/repaired very economically, they won't move well as most don't want to spend much anymore repairing any older tractor..
It s a simple matter of supply and demand. The simply isn t enough demand for them for a shop to justify the cost to make them. They would be expensive to say the least in small quantities.
I ve wondered if a model 100 off an IH would work in place of a psb.
Yes, on six cylinder engines but not four. I custom fit an IH M100 on a Cockshutt 570 Hercules 339 about five years ago. Starts and runs much better than the PSB did but was NOT a fun job..
The pump on my 66 diesel was hard to start. Took it to a neighbor who owns a diesel shop. He sent the head to Mississippi, then to South America. It is back at his shop. I am waiting on him to find time to finish. This process has been lasted over a year.
