Injector Problem
crocket104
I have a Ford 5600 Tractor that blew an injector line off. The line came out without the little compression fitting and what looks like a clear plastic coat fastened to it (I say this by looking at the other end that came off the pump). I don't know if it came out or is it still in the injector. Can somebody give some guidance? Than You in advance
Sounds like you broke the end off of the injector line, take the nut off of the injector and remove the broke part.
You'll need a new line for that cylinder.
Also you'll get more responses to issues with your Ford tractor if you post them in the Ford Section.
