injector pump numbers
Rgp
(quoted from post at 18:23:58 06/01/19) Why not just buy the seal kit here at this site?
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto25085.jpg">
If this is the correct pump I would but I haven t got anybody to verify if it is . I question it if it is correct because it smokes bad and doesn t run right.any how I do order parts here I just want to see for sure if this is the correct pump or I don t have a problem getting a new one from here....thanks
List the tractor and engine it's on and I'll see if it's the right pump for your application. If the pump has light load advance feature as some do, just putting in a gasket set won't be all it needs. Light load advance MUST be set on the test stand.
(quoted from post at 08:27:07 06/24/19) List the tractor and engine it's on and I'll see if it's the right pump for your application. If the pump has light load advance feature as some do, just putting in a gasket set won't be all it needs. Light load advance MUST be set on the test stand.
Massey Ferguson 35 deluxe snm# 214040 on dash tag.
A 61 c 37111280 left side of motor in the seat.
I hope this helps these #s are located behind the pump on the block thanks for your help.
(quoted from post at 09:07:52 06/24/19)
Correction on the #sA61 C37111220 sorry
Re:diesel technician thanks for your help let me know if this is a pump that I need to send to you for repair rebuild or just get a new one. Thanks for your help
