Injector Pump Seal Kit Recommendation
profitt
I am looking for a good seal kit for my Roosa Master DBGVCC429 injector pump. The kit I need I believe is Stanadyne #24371. However searching the internet I am finding large differences between suppliers, what is pictured and what I find in the manual exploded view of the pump. Does anyone have a good recommendation for where I can purchase a seal kit for this pump?
I have read many posts and appreciate the varying opinions on the wisdom of tackling this job.
If you have never rebuilt an injector pump you best not even try they are not something for a novice to do. You need a lot of special equipment to get one set up correctly and if you do not know what your doing it could cost yo u3 times as much to get it right after you have played with it
For the DB pump used on the 7.3 in Ford trucks the seal kit is around $50, from Northwest Fuel Injection Columbus Grove, Ohio.
Thanks, but my dilemma is the ebay kits pictured show slightly different parts. Some with wire clips of some sort some without, etc. I am looking for a reputable vendor that sells the correct seals for this pump. Ebay seems like a bit of a crap shoot.
(quoted from post at 19:23:30 08/14/17) Thanks, but my dilemma is the ebay kits pictured show slightly different parts. Some with wire clips of some sort some without, etc. I am looking for a reputable vendor that sells the correct seals for this pump. Ebay seems like a bit of a crap shoot.
Don't think you'll find anything better anywhere. You'll likely find the same thing and pay more for it. Bear in mind these kits are not built for just one specific model of pump. There are parts in them you won't use in your punp.
