Injector Question
When bleeding the system at the injector and one of them when tubing is cracked dribbles instead of pulses and also causes the motor to die is it safe to assume the injector needs attention.
Think of the order here. The fuel hasn't reached the injector yet, so it's not the problem. Sounds like injector pump to me.
It's before the injectors, so you are seeing a lack of line pressure pump-side. Could be a blockage or it could be a problem with the pump. Is the dribble happening on just one line, or if you crack them all, will they all just dribble?
Colin, MN
Problem solved.
Bad injector. It's on a 2 cylinder. My reasoning was wrong. I thought the one that was dribbling was the problem, but it was the one that was squirting, and to my way of thinking, that was the problem. Thing was that injector wasn't feeding enough fuel. When I cracked the nut there was no difference in the idle. When I cracked the nut on the other, the motor dies because it wasn't getting enough fuel to stay running.
New injectors solved the problem.
