Mike SE IL
This is so simple I feel dumb asking it. Fist a little background. I was using Old Molly (Gramp's old 560 Farmall) to dig a post hole. When I put it in the shed there was steam coming out of the radiator cap but the temperature gauge hadn't moved. OK, after 11,000 hours maybe it was time for a thermostat and a gauge. We determined the thermostat wasn't the problem because there wasn't one. I put a new one in anyway. Got the old gauge out, put new one in the dash, installed sensor bulb. That's where my problem developed I can't explain.
There's a nut that pushes against a flange on the sensor bulb to hold it in place in a brass adapter that screws in the head. Holding it in my hand I screw it all together and it fits tight. BUT when I put the adapter in the head, insert the bulb and tighten it down the nut gets tight but the bulb is still loose. Removed it, in my hand it gets tight, reinstalled it won't get tight.
After sleeping on it I suspect what is happening is when I tighten the adapter in the head it is compressing the brass fitting just enough the nut gets too tight to turn before it bottoms out on the flange on the bulb.
Sound reasonable? So what is the solution?
