Instant Reverse PTO slipping
junkbucket80
Newbie to the hobby here. I have a MF204 with reversomatic (aka instant reverse). I think I found my problem, the PTO is weak while engaged and it affects the hydraulic pump. If I manually spin the PTO shaft while its engaged it will spin for a little while then eventually tucker out. How do I go about troubleshooting this? Is there a clutch for the PTO? Maybe that got dirty? Do I need to split the tractor to fix it?
(quoted from post at 21:16:10 08/30/22) That trans has NO PTO clutch. The FORWARD and
REVERSE clutch packs are ALL you have to work with.
How hard is that to change? I have the parts manual and the Jenson repair manual but it doesnt make much sense. Thanks Dieseltech for your help.
