instrument panel gauges
While doing repaint work to the instrument panel area of the 504U the amp meter's bezel and lens became separated from its casing.
Should I be endeavoring to fix it somehow, or are any of the replacements available (like on eBay and the like) even worth considering?
I've thought about changing up the dashboard with some alternate gauges, but am not interested if the cost would be extravagant, or, if the readily available instruments aren't going to hold up.
Is there any particular ones I should be considering?
just go on ebay and type in your model number for a search. I think all gauges are made over seas anyway. good luck
The original is crimped on, If the crimp failed, I would put it together upside down on the bench weight the back, and use Lexcel sealant to glue it
back together. Let it cure for 2 days. The product can be found in squeeze tubes with a "cutoff" snout. Jim
