Int. Cub color?
whigg
I just picked up a int. Cub low boy. I believe it to be a 1963. It has red paint under blue paint and the
outside is 2 coats of different yellows. Can someone help me with what color it should be. I believe
yellow with white wheels. ( The vin is 167477 J ) thanks for any help.
Double check your serial number Low-boys only had 5 digits.
If it is a 164xx or 167xx, it would have been red with a white grill or yellow with white grill. Like these two.
Other information I have seen states the front wheels and rear rim centers were white.
(quoted from post at 00:24:29 09/24/22) Double check your serial number Low-boys only had 5 digits.
You are right. It is 16477. Thank you. Yellow and white.
The standard color for your tractor would have been entirely yellow. Some white was added with the sheet metal change later in 1963.
