Interesting situation regarding batteries.
oldtanker
My 1206 Farmall uses 2 3EH batteries. Kinda interesting as just a few years ago all 2 of the local parts stores and anyone who sold batteries always has at least 1 pair on hand. None of my 20 miles or less places now carry them in stock. They have to be ordered. No regular 6 volts either. Cause I was curious I asked. Those too have to be ordered.
I guess I will be looking into converting the 1206 to single or dual 12 volt battery/ies. Glad I already converted the other older tractors.
Rick
LOL that's won't work too well. The batteries are a goofy size. 10" tall. 19" long, about 4" wide. 3ET would be the 12 volt equivalent that would fit.
Rick
I dont see that size on the shelf much around here either. Last set of 3et i got had to be ordered but i had them next
day.
(quoted from post at 22:16:22 05/10/19) 3et and 3eh are at all the local farm stores here just
bought two new sets in the last 2 years
LOL SV, our local farm store is 25 miles away and I don't trust their tractor batteries too much.
Rick
Those long lean batteries were just a poor idea . Time to weld a battery box large enough for two group 31 batteries .
SV, gotta agree, I had my son in law pick up the ones I ordered, Decka's . Hope they last more than just a couple of years.
B&D yea that's what I'm thinking. Next time it need batteries it's time to change over.
Rick
I had a hard time charging/jumping my one tractor a few weeks ago, started looking to make it start easier. Wanted to replace the two group 5D six volts with two twelve volts, but the six volt batteries are 1000CCA each, AND I couldn't find 12 volts the same size. Today I picked up two brand new JD six volt batteries and they made all new cables for me as well- 2/0 welding cables with crimped ends and shrink wrap.
I was just about finished putting all back together when it was time for dinner with Mom and MIL here tonight, hope to finish it tonight. New batteries $142 each plus $98 for three cables. I'll let you know of this solves some of the problem.
200+ dollars is a lot of money. If the
tractor sits months at a time, buy a 20
dollar (usually less than 1 watt output)
solar cell maintainer. If you gain a year
or two battery life, it is money well
spent. Also, good cables are a must on dual battery systems. We had the same side battery go bad more often than the other side. One was getting 12 volts charging and the other was getting none (over simplified for the story) because the cable should have been replaced long ago. Get rid of the bolt together emergency-only battery clamps too!
Karl f
What kind of tractor? Changing 2 six volts out for 2 twelve volts calls for CAUTION. Is the system 6 volts now? What is your goal? Are you changing the system over to 12 volts?
(quoted from post at 20:44:41 05/11/19) What kind of tractor? Changing 2 six volts out for 2 twelve volts calls for CAUTION. Is the system 6 volts now? What is your goal? Are you changing the system over to 12 volts?
Lot of the IH diesels were 2 6 volts hooked in series to produce 12 volts. If a guy goes with 2 12 volts gotta go parallel to stay at 12 volt. May have to go to heavier cables to handle the amperage.
Rick
(quoted from post at 03:57:23 05/13/19)
Rick
twice the voltage equals half the amperage. u don't need heavier cables to switch from 6 to 12 volts. you'd need heavier cables to switch from 12 to 6 volts.
Tanker We have already changed ours to 31's with the stud top. Less fooling around and 1 battery will start them just fine even in cold weather. We have done this on 806,1466,and 4166 will do it on our 856 when the time comes. 2940 Deere got the conversion when we changed that too.
The reason for going to the stud top was 2 fold no clamp business to fool with getting over tightened and the ols batteries from my semi would get used in the tractors to finish out the rest of the set.
