Internasjonal. 633
Vintage ihi
Hi
Have the cylinderhead bolts need too bee Replenent egen you renove the cylinderhead fore broken head gasket, its to length og the Bolts 6 its 9/16 * 123 and the rest og the 9 its 9/16* 146
Vintage welcome to YT! It is obvious that you are not
able to use English very well. So it is hard to figure out
what your post means. Your tractor is probably a
European model so I do not know how much different it
is from a USA model. The information I have from a
repair manual does not say that the bolts need to be
replaced when replacing the head gasket. So only if
there is something wrong with the bolts like bad
threads or stretching that you can see would mean
they should be replaced. Now if information comes
with the gaskets that says they should be replaced I
would then follow that and replace them. If you decide
to replace them here are the part numbers
(6 required) 3138747R1 BOLT,Cyl Hd, 9/16 - 12 x
123mm
(8 required) 3138748R1 BOLT,Flng, 9/16 - 12 x 5-3/4
(146mm)
It is very important that the surface of the head is
checked to be flat with a proper straight edge.
The day i check to bolt fore the lenght i find only 9/16 *123 mm, so i baye 6 of them , but the day i remove the cylinder head was tre true aborter one , 8 Bolts og 9/16* 146 , there its nothing wrong with the Bolts , head , or cylinderblock or the Lines only blowed gasket betwin cylinder 2 and 3 , i eik ask ny dealer in Norway after the weekend..about the Bolts replenent or not
